WHAT NUMBER & DEPTH LEAD FLASHING FOR CONSERVATORY ?
13 Oct 2006
Worcestershire
hi, need some advice concerning lead flashing....i have seen that it is coded..could someone advise what code number & width( if applicable) i would need for a conservatory..the size of the conservatory is approx 15ft wide by 10 ft depth ( if that helps in anyway)...many thanks in advance
Cod 4 or 5, Google it should lead you to manufacturers recommendations, allow 150mm upstand from top of conservatory - if you are in high exposure area include cavity tray.
300 mm code 4 .. 150mm up and 140on the roof . :) 10mm in the joint .
code 4 is more then good enough. width of flashing depends on where your nearest bed joint IS, :LOL:
buildtec will you stop adding your advertising link please.
Mod Rupert
