what Oil Boiler size?
28 Jun 2009
Nottingham
I am in the process of moving house but the boiler and oil tank has been removed. The property is a fairly big 1960's built 4 bed detached.
Can anyone advise what size oil boiler i need to supply hot water ad heating?. Also what size and type oil tank is best. (There is no mains gas in the area).
Thanks for any advise in advance
You could do a heat loss calculation, but if the radiators are already in place, that is pretty pointless.
Measure up all the radiators, add the heat capacity of the lot up, and that is the size of the boiler you need.
Should be more info on this in faq
