Hi Guys,
Sorry to ask, no doubt again, about what boiler to get.
I'm moving house. The new one has an old coal fire, back boiler arrangement which will be coming out. There's no mains gas so I'm thinking oil is the way forwards.
The house is 3 bed, 1 bathroom, 2 living rooms but all the rooms are small so space is an issue. (in total about 75m^2 I think, certainly no bigger)
I'm minded to get an external boiler because of space issues however I can't find one that's rated as a A or B and I would like an efficient one.
Having read some of the threads in this topic I also want one that is easy for me and any visiting engineer to fix! No lost grommets, fiddly pipes and those cools things that cause water to leak from new and exciting places (Main Medway did get a mention).
Having said all that there is a small outbuilding and since starting my search I've noticed boiler house units that are cheaper! I assume that's because they are neither weather proof or crammed into small boxes for internal instillation. None are combi however.
So, I have 2 main questions.
Is there any manufacture or units I should steer clear of? Reliable is more useful than cheap.
Given space limitations is an external combi worth pursuing despite lower efficiency and higher cost?
and perhaps - should I skip combi and go for a boiler house model as they appear to be cheap, reliable and easy to fix? I'll stick with hot water tank in spare room if needs be.
Futher reading lead me to the impression that combi boilers may me more trouble than they are worth, at least 18 months ago. Is this still the case?
I know this is somewhat vague, but between you there's years of experience which counts for a lot.
thanks in anticipation....
mike
mike
