Hi guys
I have had to pull my mums en suite apart due to the shower leaking and the plaster board falling apart. The room is basically build in the corner of another and has 2 block walls and 2 stud walls.
The shower cubical is on one stud wall and one block wall. I was going to replace the plasterboard with moisture resistant plasterboard and then tank.
However when stripping the tiles from the breeze block wall the plaster behind has mostly come away with the tiles the whole way back to the block work. So i now need to replaster this before i can tank then tile. The plaster is roughly 15-20mm, what plaster should i use? bonding then skim with muiltfinish?
The reason i ask is i want get on and finish the room as soon as possible and i know you are supposed to leave bonding 2 weeks to dry out and then having to wait for the skim to dry out as well means the job will take ages to finish. Is there a quicker method i could use so i could tile sooner?
Many thanks for any help
