plugwash said:it all depends on the distance and how much volt-drop slack there is in the current feed to the shed.
and how long is itmdbalson said:The feed to the shed is 6mm 3 core SWA on a 32amp breaker
& the distance to the floodlights is about 10m (I will check the distance tonight)
newspark_paul said:From the post I believe you want to:
Install an SO on your patio. Why are you feeding this from your shed?
This would be a much easier job feeding from inside your house.
newspark_paul said:Why don't you run the 3 spost and the playhouse light as a single circuit?
You may even be able to include the pump on this circuit, but worst case is 2 circuits.
newspark_paul said:Your proposed use of 4-core is mis-using the cable. It is not designed to supply 2 separate circuits. Think about the loads and how they affect your cable. This is not the first time you've asked about 4-core this way and the answer is not going to change.
newspark_paul said:Why have you not raised this at college?
