Hi
I am building extension at the moment and will be installing door linings soon. Most of the internal walls are the same thickness and am planning to use 133mm wide door linings. However, there is one wall which leads in to a small room which is single storey so the there is a cavity of 100mm on top of the two skins of block. Just wondering what sort of width door lining is best to get a good fix to the block work? I don't really want something that is 300mm wide as this would a bit strange, but wanted as close to 133mm to match in with the rest.
Is it worth wedging some timber in the cavity to fix to? There is a catnic above so cant really fix to that.
Any advice appreciated.
Cheers
Ad
Cheers
Ad
