Just wondering what size header I should be using and what bolts and spacings for installing it.
The roof will be approx 10degrees spanning 3.1m and a width of 4.7m. The 4.7m header will be attached to a brick house wall and will be using 6x2 @ 400mm spacing attached to the header with hangers. So will attach the wall one side, will secure on to a timber ring beam on a conservatory the other side.
Deaf weight wise it will hold 6 ish sheets of HW Ply and either roofing sheets or shingles.
Thanks all.
Thanks all.
