Hi
I live in a 3 story home. I recently did away with the copper cylinder & installed a pressurised one (Santon), but at the same time I moved it up a floor (now on 2nd floor). I noticed that 22mm pipe came in (up from the kitchen) to the orig cylinder at the area in the bathroom and on to the airing cupboard/cylinder (where I replaced all the pipework from - basically I totally re-did the bathroom). So I carried on with 22mm in the bathroom, and up a floor to the new location of the pressurised cyl.
Hot water takes 25 seconds on full to reach the kitchen. Is this literally due to the additional journey the water has to make or should I have used 15mm? A friend advised that pressurised cylinders should all used 15mm pipe and it's the volume that's slowing the journey time down.
If so, would it matter if I replace the 22 with 15 in sections/areas I can do it easily (as there 'are' some areas which I can access without too much hassle)?
Thx 4 any help.
Thx 4 any help.
