I'm renovating my farmhouse and converting 2 farm buildings for my family. We want to connect to the mains water supply (spring fed currently) and I want to know the size of pipe required. I have to lay at least 700m before the last few meters connect to the houses. Issue is that if it's 63mm or above then I need an approved contractor which will cost a fortune. Would a 50mm do and then 25mm or 32mm for the last stretch. Or could I run 3 lots of 32mm pipes for the full 700m or so?
