H
HiZ
Replacing the bathroom suite at the weekend with a view to replacing the boiler and converting to a presurised combi system in the future. As a hot water supply is already in the kithen would I just tap into that and cap off the airing cupboard end when i do the upgrade? Reason is that the kithen supply is 15mm and the bath is currently 22mm.
I can see under the bath where this reduces to feed the kitchen.
Im fitting a shower bath mixer valve at the weekend so shall i run 15mm hot and cold? Is a combi grunty enough to need 22mm?
I guess the same applies to the upstairs cold supply but under the bath I can tap into the mains supply to the loft (which will get capped off and removed when I upgrade)
Cheers
Cheers
