What size screws for fixing 50mm post to brick wall?
8 Sep 2010
South West Wales
Hi all
Will soon be fixing a 100mm x 47mm baton to the side of the house to hang a gate from....
Please could someone tell me what size screws/plugs I'll be needing? The gate is quite heavy so i want to make sure it is solid.
Any other tips welcome!
Cheers
Max
a 4 inch concrete screw would do the job. assuming the 100mm face is flat against the wall
Hi
Thanks for that...
Elsewhere I have been recommended 150mm/6" frame fixers. Would you say they would be any better?
Yes, you are right - the 100mm face will be flat against the wall.
Cheers
I dont like frame fixings as concrete screws are so much faster and easier to use. They will work just as well though.
I only said 100mm fixing as if its into a cavity wall you don;t really want to use a 150mm and be right through the into the cavity. Thats not really a problem but better not anyway.
A 125mm 5'' fixing would be better i suppose.
