Hi All
Got a small window to fit in garage, top opener, i have ordered 160mm x7.5mm SDS masonry gold screws/bolts.
What size bit do i need, a 210mm 6mm or 6.5 mm ??
Should i drill through the frame first with a normal HSS metal bit, before i go into the brick with the masonry bit ?
Also can someone recommend a decent glue/activator and how to apply it for when i apply make up ( will be getting from Screwfix ir toolstation) as i have heard some activator can 'yellow' the upvc.
Cheers
Cheers
