What size SWA do I have?
28 Jan 2010
Just a quick question - I have some 3-core SWA, each core has 7 stands, the diameter across the copper is about 4mm - what size do you reckon it is? (I know pi r squared doesn't work because it's stranded and I don't have a vernier to measure each stand)
Anyone care to hazard a guess? :)
I'd say 6mm^2, but I thought I would ask those who use this stuff all the time...
Many thanks.
Dunno. Might be.
Is it not stamped onto the sheath of the cable?
Maybe take an offcut to your local B&Q and match it to one of their cut cables off the shelf?
Do B&Q sell SWA cut? AFAIK, they only have 10-20m drums shrinkwrapped. They may take offence if you start opening them up.
2nd what RF says, SWA usually has the number of cores and the CSA on the outer sheath of the cable.
It was everso slightly tongue in cheek and I don't think they do much bigger than 2.5 or 4mm, but they do g/y earths and meter tails, that was all. There isn't room on a certificate for 'looks like 10mm!
PS I like AFAIK - hadn't seen this before
