Putting partition walls into new extension, which has doubled up joists in place to take the majority of them. However one has an alcove in it so departs the joist at right angles for a few feet then turns to carry on but not over any joists.
Obviously I undersdand that I need to put timber work in to support it, both as noggins across the gaps and also running parallel between the joists, but what size timbers should I use? would somthing like 2x4" be suffiecent of does it need to be bigger? Should I use the same size among the rafters to fix the head plate to?
Many thanks,
Anthony
Many thanks,
Anthony
