Hi.
Hoping someone can help with advice as our old water supply has failed.
We live on an old farm where there are four residential properties. Our water supply pipe (communication pipe??) has failed and needs to be replaced. This is a steel 2 inch supply which comes to the farm from the water main which is 1.3km away. The pressure has always been low, but is now pretty close to non existent. The pipe has either furred up inside or sprung several minor leaks (apparently it's acting like a colander).
As we're crossing a neighbouring farm, we can only put in one pipe due to eavement rights. So, my question is - is it better to put in 32mm? 50mm or 63mm? The pressure is very high at the water main but how best to retain that pressure over such a long distance?
Any advice greatly received.
