I intend to fit a new power shower in our ensuite and would like some advice of pump spec.
I want to place the pump in the airing cupboard on my landing.
Hot water will be drawn off of the top of the cylinder which is also in the cupboard and the cold supply from the tank in the loft.
The problem is that i need to use the existing shower pipework which is also in the loft and so the pump would need to push the supply from the airing cupboard floor level back in to the loft and then down to the shower.
I had thought about taking up the landing boards and going direct and up to the shower but the work required would be horrendous.
Would a positive head pump work in this situation bearing in mind the shower pipework in the loft sits only about 2' below the old water tank or should i go for a negative head pump?
