I need to use a small piece of steel pad to sit over my cavity wall construction.
An oak beam will sit on the top. This will be 300 x 300mm in size and span 3m.
I need the weight to be spread between the brick and block work so thought a steel pad is the best way.
What thickness steel do i use and should it be stainless or can i just hammerite a standard steel pad ?
