I've been using a garden shed (built by the house's previous owners) as my workshop for a couple years and was about to insulate it. The walls were ply with a vapour barrier behind it, but just the studs and cladding behind that.
My plan was to stick a breathable membrane and kingspan between the cladding and the vapour barrier, but when removing the vapour barrier I can see the cladding is damp and starting to rot.
I've only recently painted the external walls of the shed and I don't think it's coming from there, I think it's coming from the ground up - the rot is worse at the bottom, especially on one side.
The shed is on a concrete slab and I think the wooden floor is just sat right on it.
You can see some photos here: https://photos.app.goo.gl/HDAsgjuD4KcKpLr98
I'm guessing the only way to fix this is to tear it down and start again, but it's a 20x15ft shed FULL of stuff I'd have nowhere to put while I rebuilt it…!
So, is there anything I can do? Even if just to slow things down?
All suggestions gratefully received!
