What To Do Around This Door To Look Good?
4 May 2016
Not a pro at this so not really sure what to do here:
Wall needs plastering obviously but there is a square trim around the door. If I plaster this wall what do I do when I get to this trim?
Normal angle bead won't work here. Not even sure if I should use any type of beading. If I plaster with no beading the wall will stick out past the trim due to thickness increase and I might have to sand the ends.
Thanks.
I ended up wedging a galvanized steel bead between the top wall and plastic trim then plastering to it.
For the right hand side I just plastered to the plastic trim and used a sponge to blend/curve the plaster into the trim.
Looks pretty good.
