- Joined
- 5 Jan 2016
- Messages
- 234
- Reaction score
- 8
- Country
hi Guy's an girls!
new here and first post so hi!
Doing some work on our first home and i can see this site being a lot of help!
Our garage is in need of a base. its currently just gravel and mud. its 9.8m x 3m internal built with 440mm concrete blocks. the garage was originally half that size and it's been extended. foundations are quite wide but the problem is the level of the garage floor run's down so the bottom footings are below ground level. the top garage footings are 1 concrete block higher than the bottom half of the garage footings but the roof is obviously level if you know what i mean.
I have had a quote for £570 to pump a 6" base but not sure if i should do it as one whole base or split it into two with some expansion packing to divide the two slabs? also should i pack around the edge against the walls with expansion packing too?
its mostly going to be used for my bikes but may one day in the future have a car in there so best to think ahead! it's a garage after all!
