What to do with the hot feed?
FB
7 May 2006
Manchester
Am getting a new cold-fill washing machine and was wondering what to do with the redundant hot feed hose. I presume I can just disconnect it but what do I cover the valve with?
why not just tie the hot pipe up, with valve turned off you may need it later
Good point - Any risk of it leaking if I do that?
Also it is okay to use the old cold feed hose (6 years old)
so long as the valve doesnt leek then yes, yes you can, and as for new pipe depends on condition of washer, change it if you like
