Hi there
Forum newbie here wanting to pick your collective brains on advice for some tools.
Currantly a plasterer and after spending time working with a property develper at weekends for the past year I'm looking into investing in a few properties of my own with some money ive saved over the years. I have a fair amount of kit already but mostly skewed towards my current needs as a plasterer. Ive a resonable amount of experience in other trades and have the old mans 40 years of experience to help out but hopefully the proper kit will help produce quicker and better quality results with less struggling!
1. cutting: At the moment i have a makita 5704rk witch i envisage has years of use in it. I use it for ripping pyroc/bluclad boards atm so it doesnt get that much use. Also own ryobi 18v circular saw and jigsaw witch are of limited use tbh but came as part of a very cheap set. Have acsess to an old SIP table saw too as well as the usual handsaws of various types. Im considering the merits of a plunge saw (probs makita, dewalt or bosch) although at over 300 quid there not cheap. Should make ripping sheets in the day job a doddle tho! Also after a sliding mitre saw probably a hitachi c8fse and jigsaw probably a cj110mv. so my question is is the plunge saw that much better than a standard circular on general renovation work and do I have any other cutting options I've missed?
2.Lasers: Can anyone explain the differant types. Often use a spit cl30 cross line laser and plumb bob from work witch I believe means vertical and horizontal right? Rotary ones look useful but are pricey. I dont mind spending a good amount on one but not on half a dozen differant types? What are the most versatile+reliable ones on the market. Are tile lasers useful or a gimmick bearing in mind I'm not a pro tiler!
3.Tile cutting: My old man has a pretty good Rubi manual sliding cutter and vitrex electrical tile saw (the table saw type ones) from when he was a pro tiler. I've picked up a manual saw, scribe and pair of pincers recentley so is there anything i could add? Ryobi do an 18v wet tile cutter for 50 quid bare and I already have the batteries. Will this make life any easier? I've got a Ryobi 18v grinder so is it worth picking up a tiling blade?
4.laminate/wood floor: How do you guys cut and would the tools mention above be sufficient? What do you make of this?
http://www.qvcuk.com/qvc.product.56...urce=google&utm_medium=base&utm_campaign=base
Very cheap but with the letters GMC written down the side thats probably why! In fairness I find some cheap tools fine for occasional use, it has mainly good reviews on amazon and argos and its not like I'll use it every day. What about using it on wood and are there similar products you know of? Anyone use the bostich flooring nailer and although its not cheap could it pay for itself on a few jobs?
5. Rewire: Could be looking a rewiring properties? Any tools speed this up besides pliers/cable rods? Anyone use these or similar?
http://www.ebay.co.uk/itm/HELLERMAN...TI-PURPOSE-WIRE-CABLE-DISPENSER-/200769289587
6. Earthmoving: Could have to move a lotta soil anything better than shovel and barrow and no I can't afford a digger!
7.Door Hanging: Is there a better way than chisels and mallet? Seen a few products about but not sure how gimmicky they are?
8. Cutting aids/jigs/templates: Anything out there that make cutting and marking easier/quicker especialy awkward bits?
9. Access: I have a pair of trestles and some planks plus one of these brilliant ladders
http://www.screwfix.com/p/multipurpose-ladder-with-platform-4-section-3-rung-3-34m/27581
Will probably get a hopup with with built in work tray. Does anyone here use raised floors (milk crates/planks) for wiring/insulating/boarding/plastering ceilings or is it not worth setting up? Have looked at stillts but imagine there more bother working alone across 2 floors!
10. Other tools: I tend to find working with developers a lot of time is spent looking for the lost tape measure/pencil/knife! I've started keeping a bag by my side with a dozen of each so if I can't find them I just grab another and wait for the old one to turn up before throwing back in the bag. Anything I Should add to this bag?
11.Nailguns: Hitachi ones go for about 300 quid and I can see a bit of use for a first fix one however whats the use of second fix ones? Architraves? Skirting boards? Will the only fix to wood so is it use in an old terrace?
12. Plasterboard lifters: Going for a smidge over 100 quid on fleabay? Saves paying a mate 50 quid a day to help out if it 3 days or more? Anyone used them?
13. Bathrooms: Good bathroom fitting tools besides the obvious?
14: Kitchens: Good kitchen fitting tools besides the obvious?
Anything you care to add much appreciated. Long post but I'm sure you can help me more knowing my whole situation. Cheers
