I have laid some laminate floor and the joint between the new floor and next room is around 20mm in height then 15mm with some pressure on the end of the boards.
Is there a transition strip I can use that will take up the difference in height and be fixed down to keep some pressure on the end of the boards?
The flooring is Quickstep in a light oak. The incizo bar I have doesn't seem appropriate.
