what tv fixings ?.
9 Nov 2005
Coventry
hi, ive been asked to fit one of them big flat 42 inch t.v,s to a solid brick exterior wall / as they are very heavy [ and expensive :) ] im not sure of what fings to use . ie. expanding anchor type, or the big brass type that screw direct into a hole drilled into the wall.
its a plastered wall with breeze block first then brick. with a cavity . [ so im told ].
oh/ of coarse its the wall bracket i want to fit on the wall for the telly to go onto.
advice please. regards. r.r.
thanks for that ch427, will follow that up/ . and yes most defintaly safe than sorry. regards. r.r.
:) thanks for reply triplerated, job now done/ had to use 10ml threaded bolts right through wall in the end .[ dont ask ] :) it will never fall down anyway, .. regards. r.r.
