Hi all,
I have a mixer shower (Newteam) which is fed from the hot water cylinder (via a special flange of some sort I believe).
When it's first started up it sounds like it's pumping air for a while before the water starts to come out and the pump motor goes nuts. It doesn't appear to have any check valves in the 15mm supply pipes..... should there be, and if so do I need the single or double type ?
Thanks in advance.
Kind Regards,
Robin
Thanks in advance.
Kind Regards,
Robin
