I'm new to the forum and would gratefully appreiciate any help offered.
A couple of years ago I built one of those 'log cabins' in my back garden as a way sort of home office / games room. To fit in its space we had the cabin custom built and to keep in with the neighbours the roof was kept as low as possible so the pitch is low. Roughly 10degrees. It came with felt tiles that we fitted and it seemed to be ok but over the last few weeks it started to leak near the bottom of the pitch. Long story short but I ended up taking down the false ceiling inside and sure enough it has been leaking over a section about 500mm square. As the weather has been very bad I removed all of the felt tiles and have temporarly fitted a thick plastic sheet to protect the roof.
I am now looking for a new roof covering. I think the original problem came from the felt tiles not being designed for use at such a low pitch. The roof is made from 20mm thick tung in groove pine boards which I have treated with wood preserver so while they have got wet they seem fine. I think the way foward is a standard felt roof but this cabin cost enough to build that I want to protect it with something better than cheap shed felt.
I was thinking of running bitumen into the joints in the wood. Then fitting a heavy duty felt. Would it be worth leaving the plastic sheet under the new felt? Looking into it myself I've came across multiple layer felting systems that may prove better. There are so many options on the market that I'm not sure where to start and would appreiciate any help or advise available. The total area to cover is roughtly 3.5x3m The roof is a mono pitch running on the length.
