Our current renovation stage has moved onto the flooring part and we have lifted up all the old flooring which was old parquet stuck down with bitumen.
There is still abit of bitumen on the floor which we are not sure if it contains asbestos so we are not going to tackle or touch it and instead have read that we can just clean and seal over with Arditex NA, which we have done with a dual-layer.
Floor is a concrete slab with DPM already underneath, the house is 1970s and hence had abit of settlement overtime and the difference between some of the high/low spots in the room are equivalent to around 30mm in variation difference.
since we are DIYing it, we are going to stick with self-levelling products due to them being easier overall to work with (but obviously more expensive).
I know that some screeds have a certain 'minimum' thickness required to stop from cracking, but my floor is quite uneven and bumpy, but the highest variation between the highest to lowest spot is 30mm. so there will be areas that will only have 10mm, 15mm, 20mm screed etc. So with that, do i then need to find a product that has a 'minimum' tolerance of my lowest point (possibly 10mm)?
