I have created a new waste out of 32mm solvent weld. I have used all Hunterplastics items for this, which are nominally 32mm (actual 36mm). (I know it is possible to join compression pipe to solvent pipe by using a straight compression fitting).
So, I have a solvent weld upstand pipe for my washing machine output. I want one of those little spigot caps that go on the top of the upstand pipe to seal it off except for the part which the washing machine pipe attaches to with a jubilee clip. But, the washing machine spigots from McAlpine etc aren't' designed for solvent pipe as far as I can tell? So is there a solvent weld version anyone knows of
this sort of thing (but this is 1 1/2")
thanks
thanks
