I have a house that currently has a fireplace (surround etc) with a gas inset fire. The house, detached is approx. 15 years old
The chimney is external (so juts out on the outside wall rather than inside),
We want to go for one of the gas hole in the wall fires, so we're looking to replace the existing fireplace and the fire.
I've had two gas safe engineers out, but they're conflicted each other, in terms of the max size fire we can have. Both visited the house, has a quick look inside, and then spent as few minutes outside measuring the chimney breast.
One fitter says we needs to take two brick length off the left and right sides (for structural reasons), the remainder size is the max fire we can have (in this case 60cm).
The other fitter says we needs to take one brick widths off the left and right sides (again for structural reasons), the remainder size again is the max fire we can have, but in this case they stated we can have almost any fireplace out there.... I queried could we have one sized 80-90cm and they confirmed yes...
Can anyone please confirm who is correct
The reason for asking is the 1st fitter has fireplace package that we really like the look of, but he's stating it's approx. 80cm for the fire so cannot be fitted without major structural changes.
Both confirmed the depth is not a problem, and the chimney itself is fine for any type of fire.
