Hi, I have a newly re-wired kitchen (by an electrician, all signed-off and properly certified) and they have left me a safely terminated 230v cable coming out of the wall that is ultimately connected to a wall switch so that I can add LED under & over cabinet lights once the new kitchen units were fitted...
Anyway, the units are here now and I am about to order the 12v LED driver (transformer) and white LED strips (60 x 5050 SMD LEDs per meter).
I'm very competent with 230v mains wiring but I've never really done any 12v stuff so this might sound a daft question...
I plan to have 3 indiviual 1m LED strips under the units and I've calculated that they will be draw power of 14.4 watts each which at 12 volts means a current of 1.2amps. Above the units I will have a single 3m strip which will draw 3.6 amps.
I plan to connect each of those in parallel to an LED driver with suitable capacity.
My question is... what sort of wire/cable should I used on the 12v side? I did have some of those RGB LED strips and the pre-installed wires from those seemed incredibly thin. Because of the higher current on the 12v side I presumed I needed decent thicker cable?
1mm T&E would be fine from a current point of view but given that I have to cut & solder the LED strips to exact length then I really need some sort of multi-stranded 2 core wire instead. I'm not sure of the proper name - is it "equipment wire"? Although elsewhere I saw someone (when talking about doorbells) say that solid cores were better for DC voltages.
I saw this 6amp two core mains cable at Maplin that would presumably also be fine, but I wanted something more discrete without the external sheath since it is only 12v:
http://www.maplin.co.uk/2-core-6a-mains-cable-3182y-83
Anyway, can anyone recommend a suiatble type of wire for the 12v side, or am I worrying about nothing? The cables will be about 1 to 2m long from the driver to the start of the LED strip/tape.
Thanks!
Thanks!
