My current system is all microbore and works very well indeed. However I now want to move a rad from one side of the living room to the other.
The length of pipework required for the new run is approximately 8 metres each way and it needs to feed a double rad with a BTU rating of around 6500btu's. Its pretty much the same size as the rad in the original location which worked fine, but will the increased length of pipework cause a problem? The original pipe run is only about 3-4 metres.
The current pipework is 8mm I think so would using 10mm microbore be better for this new location?
OR, should I tee into the 22mm feed/return before it enters the manifolds and install a single run of 15mm to solely feed this new rad?
To make things more complicated I also want to add a new radiator into the system for my conservatory. This will also be around 8 metres away from the maifold. Can this run be made in microbore or should I feed these two rads together from a 15mm spur from the main 22mm feed/return?
My preference would be for an individual microbore feed per rad as I think its more DIY friendly and doesn't require any joins behind the plasterboard (which is where I'll be runningh my new pipework), but I've heard conflicting views and thus confused.
The system currently has 7 rads on it.
