Quick question and no doubt a simple answer whats the best type of rawl plug/fitting to use on breeze block / dot and dab plasterboard walls?
Im wanting to put up a curtain pole which only has two mounting points and hang some fairly heavy suede curtains, when looked in Focus the heavy duty rawl plugs for breeze block walls are about 6 or 7 inches long, is there an alternative?
Am i right in thinking due to the weight if they arnt hefty fittings being breeze block the holes may crumble and the fittings fall out due to the weight on them?
