What's the tool called
3 Aug 2011
West Midlands
What's the tool called that can mould around shapes and angles for use when cutting carpet and laminate floor?
ExamPle would be when need to cut laminate around the door frame. This tool kind of pushes upto the frame and moulds around the angle. You then transfer this to the flooring and draw your pencil line around it for cutting.
Thanks in advance
You are best under cutting the door frames mate, so you slide the laminate under. That way it can expand if it needs too.
