im clueless as far as cars and vans go a red light has come on, on my dash. Its a fan inside what looks like a can with a bit of liquid at the bottom what is it. cheers
^neo^ said:Means your tv license has expired, and your wife has run off with the postman.
What car/van? Sounds like a coolant level light to me.
keyplayer said:^neo^ is correct - it's the coolant level. I've got a Boxer and had similar symptoms. Strangely I found it needed topping up a few times before sorting it - the header tank seems to be compartmentalised in a peculiar way on the Peugeots, but it will find its own proper level eventually. I would reconnect the fan if I were you.
