The hot water from my boiler is making its way up the cold feed pipe into the c/h f+e tank causing it to overflow, the f+e pipes are just before the pump....ive tried everything but the only thing left to do is bleed the pump itself
do you do it when the pump is going or when its off.
do i do it with the system hot or cold
how do i do it, is there a valve or do i release the big silver screw.
mike
mike
