Hello I'm new to this forum and to central heating systems!
I have just moved into a 1930s house with open vented central heating system
A while ago I noticed that the central heating comes on when only hot water is selected on the control box and worked out that the fault must be with the motorised valve. I have a replacement valve (well the backplate and ball as the electronics are working fine) but haven't yet fitted it.
Yesterday I noticed another problem in the loft. When I am running the central heating water is dribbling into the expansion tank. This is a constant trickle (i.e. more than just frequent drops) when the heating is on, but when I switch the heating off it stops. I have reduced the CH pump to the lowest speed setting (it was on the middle setting) and the trickle is reduced to a frequent drip (about 1 per second).
The radiators are getting warm when this is happening.
As I'm new to heating systems I wondered what could be causing this problem? Can anybody here help?
If this has been happening for a long time is it possible that there is no inhibitor in the system?
Many thanks!
Many thanks!
