I'm in the process of obtaining quotes for a replacement combi boiler. The house is 13 years old (built 1999) and has 4 bedrooms. We currently have an Ideal SE Combi with 15mm gas inlet pipework that disappears into the wall directly behind the boiler.
So far, the quotes we have rightly state that we need to change the gas inlet pipework for 22mm type. BG wanted to replace the whole run, from the meter to the boiler (the whole length of the house) and even suggested putting the pipework on the outside wall (that would look nice I'm sure you'd agree!).
The current pipework goes into the garage behind the meter box, up into the ceiling void and runs across the house in the void. What I'm not sure of is at what point does the pipework switch to 15mm.
I don't really want to start lifting up floorboards until I really have to.
The Gas Fire pipe comes down about halfway across the ceiling void and is also 15mm. Would the pipe work for the boiler also change to 15mm at this junction?
I read on another thread that the building regs change stated that the last 1m of pipework into the boiler could be 15mm. I assume this was so the boiler manufacturers could sell off existing stock with 15mm connectors, now they've all gone and are all 22mm connectors.
When did the regs change? Can I assume the pipework is 15mm for only a meter and the joint from 22mm-15mm is somewhere in the ceiling void directly above the boiler?
I know the HE will discover this eventually, but I just want to get a feel for how complicated this job is going to be.. Any help appreciated.
