When do you need to use vapour barrier for plasterboarding?
8 Dec 2013
Bristol
I'm drylining some brick walls in the bathroom with battens and moisture resistant plasterboard. I'm not clear on whether I need to use vapour barrier or not? 2 of the walls are external cavity walls 1 is internal. There is no damp or anything.
Can anyone advise on when vapour barrier should and shouldn't be used?
When you're building a timber frame house. Your context will be fine with MR plasterboard
