I have looked at other similar threads which have appeared on this forum but I’m still not sure of the true situation. Also, yes, I have studied Part L1B of the Building Regs but I’m not clear as to whether the exemption I am seeking applies in my case.
Can anyone please tell me if I build a structure which complies with the requirements of section 3.15 (i.e. it’s at ground level, the floor area is less than 30 sq m, existing exterior doors and windows in the main dwelling will be retained and the dwelling heating system will not be extended into the extension) I am exempt from BR? Also I can make it with as much glass as I like (walls) or as little as I like (roof)?
I chose the word “structure” carefully as it seems to me that I can call the new building anything I like e.g. a conservatory or an orangery but not an extension because that has definite connotations. My ideal structure would be one with lots of glass on one wall (e.g. composed entirely of bifold doors), a solid, well insulated, flat roof (GRP covered) with a DG roof light and the other walls of cavity wall construction with CWI. It will be south facing hence a conventional conservatory does not appeal!
Any thoughts/ideas gratefully received.
