That's impossible to answer, because I don't know what colour insulation your cable has.
If you have only red and black (and bare/green/yellow), then somewhere you've got a black connected to a red. If the new light fitting has a brown, then you might have a black connected to that brown. This is normal, so you've probably got two such connections instead of one.
Read jj4091's post again, and follow that advice.
If you can't identify the switched live wire, i.e. the one that becomes live when the switch is 'on', then you can't proceed without guessing and trying every permutation, some of which would be dangerous.
Do you have a voltage indicator, or multimeter, or any other means of safely determining which is the switched live?
