Hello:
I've been on the forum earlier figuring out a problem on my CH
(//www.diynot.com/forums/plumbing/central-heating-flowing-into-expansion-tank.393414/) and you guys are fantastic!
I now have a separate question...
What sort of calculations are made when deciding how far to use 22mm before reducing to 15mm in your central heating circuit?
On my system 22mm is used from the boiler and hot water tank for a about 1 - 2 m before it reduces to 15mm. I think three small radiators t off the 22mm before it reduces. Most radiators (seven other bigger ones) tee off the 15mm circuit. it is two rings (one each floor).
They seem to heat ok so not currently worried but I am planning on adding a couple more rads in the future.
Are there any methods to calculate the optimal points in a circuit to reduce from larger pipe to smaller pipe? Or do you pro's use a common sense approach?!
Hope this makes sense!
