I have a need to install a 32A supply to the garden for Hot Tub.
It a fairly long run of about 40m or so involving leaving the CU going up an external wall, across the loft, down an external wall to a weatherproof Mini CU. From the Mini CU I would then like to run to an Isolator switch and then to the Hot Tub.
My question is:- Since the only part of the circuit that is below ground is after the Mini CU - do I need to run SWA to the Mini CU or can I use normal cable up to that point?
Thanks...
Maurice
Thanks...
Maurice
