I'm trying to install a 2ft 18w Fluorescent strip light in my loft, but obviously, I've run into problems, which is why I'm here. I'll describe how I've set it up it in as much detail as I can, then maybe somebody will be able to tell me what I've done wrong.
I've used 1.0 mm twin and earth lighting cable, and connected the live, neutral and earth wires to the appropriate terminals in the light, then ran a cable down to a switch. I found a cable in my loft which goes from one ceiling rose to another (kids bedroom to bathroom in next room) and added a 30 amp, 3 terminal junction box to this cable. Then I ran a cable from this junction box to the switch, and put both reds to the switch's com terminal, both blacks to the L1 terminal, and both earths to the plastic mounting box's earth terminal.
The first time I turned the electricity back on, the upstairs lights all worked ok, then I tried the switch in the loft, the switch blew and tripped the upstairs lights on the consumer unit. So I turned the mains back off, checked all my connections, and fitted a new switch, but when I tried to turn the mains back on, the master switch on the consumer unit didn't want to co-operate, along with the switch for the upstairs lights. So I disconnected the switch and the new cable, but left the existing cable still passing through the junction box. I turned the mains back on, and everything was fine, the upstairs lights all worked, apart from a rather useless loft light.
Thanks for any help, it will be much appreciated. If what I've done wrong is really dumb, please try your best not to flame me too viciously.
