Where are check valves needed?
22 Oct 2012
Nottinghamshire
Read other previous posts and the wras regulations and I'm a bit confused as to where in a domestic property I need check valves and if these should be double or single. My shower has built in valves so I don't believe I need others, but is it purely on mixer taps and outdoor taps these are needed, or do I need them on the inflow to the toilet, dishwasher and washing machine also?
Thanks in advance
Double check valves (fitted within the house) on external taps
Mixer taps don't need them provided they have separate internal water channels
ANy mixer with a detachable head does need check valves fitted
WC cisterns (and loft tanks) should have a WRAS approved fill valve or a part 2 valve
Domestic appliances don't need a check valve
Thanks newboy, clear and concise- couldn't ask any more,can I ask are you a plumber yourself?
Also fitting a lone's ale filter which I've just noticed states 'a check valve should be fitted in accordance to wras regulations, does this therefore need a valve before that and the incoming supply?
