Where can I find Bath Anchors
2 Jun 2004
I acquired a metal bath with 4 adjustable legs. It is very wobbly when in position and I have since discovered you can get bath anchors to fix it to the wall. My problem is I don't know where to get them from can anyone help?
Clamping / holding a bath:
Use a bit of wood and a long screw. Put the wood up under the bath, top end against the flat horizontal part of the bath wherever you can reach it, and against (sideways) the downturned rim of the bath. With its lower end against the wall the bit of wood will be sloping out at the top. Put a long screw though it just below the edge of the bath, into the wall. Tricky at the tap end once the taps & pipes are in.
If you silicone or gripfill the bath to the wall then clamp it as described, it won't move.
