Where can I get replacement honeywell coils for valve?
10 Sep 2009
Wiltshire
HI,
Can anyone tell me where I can get new replacement coils for a Honeywell VK4105E 1007 gas inlet valve please?
Skywatch
I dont think that its possible to get replacement coils for that valve.
The whole valve needs to be changed and set up by a gas registered engineer.
Tony
As previous post has advised.
If coil is o/c. A new valve is required.
Check the Correct voltage is getting to the coil this will prove that the PCB etc is all ok
But as you will be aware coils are not replaceable on this valve :rolleyes:
EDIT: Sorry, you cant get it :-wink
Not another Suprima Valve? Done 3 in the last 6 months!
Paul
