I’m putting up a small summerhouse, cavity walled natural stone outside with thermalite inside. Wooden framed frontage. Thought I might sit the small pitched slate roof (3m x 3m) over particle board over a couple of purlins, rather than use rafters; ie the side walls bear the load, rather than the front which is wooden and glazed.
I’d rather not have the purlin ends exposed to the elements (sometimes you see them sticking out). Is it ok to set the purlins flush into the thermalite blocks? They are ‘standard’ size/shape.
Any helpful advice appreciated as I’ve never built a roof before!
