Where is the filling point
28 Sep 2004
I have a Glow-Worm Space-Saver 50 balanced flue boiler with a microbore central heating system that was installed before we moved in to the house, many of the radiators are now causing trouble, sludge build up, leaking valves etc… Is there a way to find out where the filling point is without ripping up carpets and floorboards everywhere?
There is no feed tank in the loft and I can’t find a filling loop anywhere obvious and there is no mains water going out to the garage where the boiler is.
If you have
leaking valves etc
, then you MUST by now have lost enough water from the system to stop it dead UNLESS there's either an F&E tank somewhere OR some sort of automatic top-up gadget. It's quite unlikely this would be under floorboards. Have another look around.
Clue - it'll be where the heating pipes are near the water main.
If I drain the system and the water stops coming out, i.e. there is no
would it cause any problems to fit another filling loop? There isn't any pressure gauges on the boiler, how would I know when to turn off the feed?
I assume if there is an "automatic top-up gadget" I will hear the water entering the system as it is being emptied.
