We've had our house for about a year now, it's old build (1920's-50's) with a hipped roof
Been trying to work out "the lay of the land" as it were as to whether any of the internal walls were loadbearing, so i took a look in the loft.
Anyways, the purlins have struts running down to the ceiling joists on everyother beam - distance between each joist is about 14 inchs (from memory) and beams are 2x4 (also from memory)
I did some googling and searching on here about struts and bearing walls etc
And, although one side of the roof's struts terminate near to the top of a wall - the other side come down onto the joists almost half way into a room underneath (span of the room is approx 14 foot)
Am i right in thinking that the wall underneath the struts is just a coincidence or is it load bearing? and if it it load bearing then why are the struts on the other side of the roof ok to come down into the middle of the ceiling of the room below?
If that wall wasnt there then the distance between the outer walls would be about 20 foot...... with the struts splitting the span up almost equally into 3 sections.......
