Where to find replacement screws?
r_c
19 Jun 2016
I need replacement screws for my shower screen. How do I go about buying new ones?
Our shower screen is one of those ones that slides in and out. But the sliding track mechanism has become rough and difficult to slide. I would like to remove the doors so that i can give it a good clean. But the screws are impossible to unscrew, and I've now damaged the head and given up, because ... if I do now eventually get the screws out, I have nothing to put back in!
So ... how do I go about finding replacement screws? I have no idea of the manufacturer or retailer of the shower screen.
r_c, good evening.
If possible can you upload several digital images of the Screws in question??
Someone somewhere may recognise the make and get you out of a tight spot?
Ken
You just want pan headed stainless stell screws. At the end of the day, it's normally an aluminum frame, so it'll be easy to screw into.
  • Thanks
Reactions: r_c
Maybe treat your self to a new shower screen/enclosure.
New ones have nice free running rollers,it will seem like luxury.
The old shower glass gets brittle and easily broken (been there !) so be v careful,
  • Thanks
Reactions: r_c
Actually that is the plan for the long run (you can probably see how scratched up the metal channel is). Until I do that I was hoping it would be quicker to make the guide a bit smoother ... but at my slow work rate I might be replacing before I can find replacement screws. Thanks for the warning about brittle glass - I did not know that.
Looks like you could get some grips on the screw head to get it out?
